Grinding sound when brakes applied right rear area humvee
RichDane
Hatteras, North Carolina
In my quest to bring this vehicle up to standards, along with many other changes, I have recently replace all half-shafts. I began to hear somewhat of a grinding sound when I applied the brakes and not really inspecting the pads, when I did the axles, and not knowing if I possibly knocked any one of the brake pads out of position, I checked everything and replaced the pads even though the pads were in nice shape....issue is, I still have a grinding noise when, and only when, I apply the brakes an only get that grinding noise from the right rear of the m998. Any suggestions on the cause of this noise? Everything is tight and seems ok, Rotor seem straight and not warped...I can't figure it out!!! I am open to suggestions.
Thank you
RichDane
snowtrac nome
139
western alaska
If the linings, or lack there of are causing the problem you will see the evidence on the rotors. other things cold be fasteners that you used could be too long or a bolt coming out because it didn't tighten down right. the first thing to do is crawl back under it and inspect all what you did the grinding should have left evidence
RichDane
It was grinding before the pad replacement, I used the same bolts and torque to specs for the half-shafts replacement. I have a feeling I will be underneath a lot more here. the grinding drives me crazy Thanks
Retiredwarhorses
4,176
Brentwood, Calif
Im assuming you used new lock washers or Nordlocks? That an red locktite...
this is all a MUST.
check that 5/8 bolts have not backed out of your diff hangar bracket as well.
RichDane
this is all a MUST.
Yes Sir, I was under it this morning, My Caliper maybe the culprit, not sure that it is moving as freely as the other....I will pull it off and inspect....to answer your question absolutely, new everything, With red locktite
94M998A1
NorCal
I am having this same issue except with the driver side rear after installing a new halfshaft, what did you find the issue was? I am putting mine on a lift tomorrow
94M998A1
NorCal
Was it the caliper? I put the old halfshaft back in and it still makes the noise. I found my caliper wasn’t moving as smoothly as the otherside but the rotor almost looks like it’s not being used. Going to take my caliper off this Sunday.
Bulldogger
585
Quantico VA
With that description I'd remove and clean/rebuild the caliper piston assembly. Probably needs a new seal after cleaning gunk out.
BDGR
94M998A1
NorCal
BDGR
So you don’t think just re-greasing the pins would work? Can I get a rebuild kit at a Napa or autozone type parts shop?
