Grinding sound when brakes applied right rear area humvee
Dock Rocker
72
Jackson ms
The caliper with the emergency brake cable set up is made by amg and not available aftermarket nor the rebuild kit to my knowledge. Only through authorized amg dealers or surplus.
Kascar and HPG have them. I had the pleasure of buying one a few months ago. It hurt.
Bulldogger
734
Quantico VA
That is not a civy item for a rebuild kit. Caliper or seal kit are amg mil items.
I think Juan means the rebuild kit is particular to military brakes only. The brake pads and rotors for a 1984 AMC Eagle wagon fit the Hmmwv because that's what they started with, but if I understand the evolution of the M998 brakes they had to improve them and so the calipers departed from being a repurposed civilian item.
I welcome more knowledgeable folks to chime in.
Bulldogger
teteacher101
WI
Bulldogger
Aren't the bolt patterns different on the rotors though? HMMWV's use 6 holes and I thought the AMC Eagle has 5 holes?
Bulldogger
734
Quantico VA
And I stand corrected; the front rotors for an Eagle are indeed 5 bolt, not 6 like on a HMMWV. I had heard somewhere they were the same, but clearly they are not.
I’m glad I bought the recommended pads from Hummer Knowledge Base, and not AMC Eagles.
Dock Rocker
72
Jackson ms
I believe the calipers are the same as the AMG.
94M998A1
NorCal
How common is it for the rear brakes to get jammed up and make a grinding noise? And how often was it just the brake pins needing grease?
Dock Rocker
72
Jackson ms
If the rears are making a grinding noise it’s probably going to be expensive.
Take it for a short dive and see if one of the rotors is hotter than the others. I use a laser temp gun for this but you can use your fingers but it could hurt.
Greasing the pins will kit likely result in a fix but worth a try.
Most likely you have one of two things going on. You most likely have a caliper going bad. It will be much hotter than the others. That’s the most expensive fix but by far the easiest and least time consuming.
The other likely culprit is the emergency brake cable crapping out and getting stuck in the sheath. It’s a cheaper fix but a giant pain in the butt to change.
Either way you will need to change the rotor in the corner that’s been dragging and the pads on both sides. You never change just one set of pads.
94M998A1
NorCal
The noise is instantly without touching the brakes now. It started off when I would touch the brakes but now it’s constant noise
Dock Rocker
72
Jackson ms
Drive it and measure the temp on each rotor. That will tell you if you have a problem caliper.
teteacher101
WI
How hard is it to bleed the brakes on these trucks?
Block the front wheels, put the T Case an tranny in neutral, jack the rear end up an try spinning the rear wheels by hand or have someone spin a wheel by hand to see if you can get any noise out of it that way an pinpoint it. These **** things make so much noise running an driving it can be hard to pinpoint. Worth a shot, will only take a few minutes.
Bleeding brakes on thses is really easy. Just need someone to pump the brakes for ya. :)
RichDane
Hatteras, North Carolina
Sorry, I have been away from this for a while...Thanks 94m998A1.....For me after changing everything out, trying to find the problem...I took off the new Half shafts I put on and put the old one back on (There was nothing really wrong with the old ones but I thought I should replace anyway) TAAAAADAAAAAA those new ones were the issue.....Don't really know why they were grinding but if you replaced your half shafts and you are now grinding/....Guaranteed, in more times than not, your "New" probably Chinese made Half shafts are to blame...Just saying
94M998A1
NorCal
I took my new halfshaft off and put a old halfshaft back in and it still makes the noise from the same side. So I think it’s the caliper
teteacher101, I plan on doing that today before taking the caliper off
papakb
1,196
San Jose, Ca
Unless you have the upgraded Wildwood calipers the originals are '87 Eagle calipers and cost about $18 at most auto parts stores, no cores necessary. Just replace them, it's less trouble than trying top rebuild them.
Dock Rocker
72
Jackson ms
Those don’t work on the rear. The rears are proprietary with the integrated e-brake.
94M998A1
NorCal
So I put it on my dads lift jacked up the side that was making noise and spun the tire, it seemed rough turning. Kept seeing weird things coming out of the brake/rotor, dirt or something. Dad turned the driveshaft and then I noticed the rotor and halfshaft we’re trying to move up and down before they rotated so I think I got something wrong with my rearend. Taking it to a rearend shop either this week or next
Bulldogger
734
Quantico VA
According to info sent me by another SS member, and my own recollections, I'm in agreement with papkb and DockRocker, the calipers on front are carried over from the AMC Eagle, but as noted the rear are improved to gain the better parking brake.
Someone needing front calipers can replace them easily, if it's easy to get Eagle calipers anymore! I haven't looked.
Hope you get it sorted!
BDGR
