Grote Solid State Flasher Install
donquijote
36
Louisiana
I am planning to install the Grote 44010 flasher unit in replace of the regular one. Has anyone installed this one before. Just want to make sure I wire it up right when it arrives. Attached is the wiring schematic for reference. Thanks.
Sent from my SM-N950U using Tapatalk
1,177
A search for 44010 comes up with some results.
Guessing you did not search before posting?
donquijote
36
Louisiana
Yes I searched and that thread does not show how the 44010 is wired up. Someone else PM'd me the answer to my question.
1,177
Please share what you were PM’d, otherwise this thread is not much use to others in the future.
Ajax MD
1,414
Mayo, MD
The search feature on SS is a great thing as almost anything you want to know has been discussed here.
Take a look at this posting:
https://www.steelsoldiers.com/threads/economical-turn-signal-flasher-repair-option.132184/
Beggin' your pardon, but the search feature on the new forum software needs some adjusting. I very frequently have my searches interfered with by the software because it deletes words that it determines are "too short or too common."
For example, when attempting to search for the DIY PVC turn signal canceler, the search omits any results with PVC. Nor does that specific thread pop up when you just search for turn signal cancel. This is just one example. I can provide many others.
I really like the new forum software and I appreciate the great effort that went into the upgrade. My criticism should be taken as constructive and in no way an attack on the admin.
Ajax MD
1,414
Mayo, MD
Well, that's how I found this posting so what can I say?
No worries. I know the SOP around here is to tell everyone to use the search engine to avoid creating hundreds of near-identical threads but people should understand that the search engine isn't flawless and not get cranky when someone asks a common question. (Not saying that you were cranky)
donquijote
36
Louisiana
The answer is that my drawing on the bottom of the schematic I posted, is the correct wiring.
Just because you search and see results, then fail to read the threads to see if they correspond to the OP's question, don't just start posting "I guess you didnt use the search tool." Maybe you should read your search result threads before posting also.
Next time, I'll make sure to state that I did search and did not find the answer to my specific question.
1,177
You asked,
That is the only question you asked. I searched to see if anyone had, and the answer to your question became obvious.
Maybe I should have simply replied, “yes”(to the question). Would you have been less offended by that?
The schematic you posted seems clear enough to relieve any doubts how to wire the flasher.
