IMP
- 8
- 8
- Fruitland Idaho
Any one know where to get 15 in o rings for the Growler ?
IMP
IMP
Steel Soldiers now has an offical calendar available, read more about it at: Steel Soldiers 2021 calendar
I'm also looking for the o rings... did you ever find out what size you needed? My rims are leaking...ThanksYes it is for the wheel I will look them up
Thank You
Do you know what size? ThanksI just went to Ontario Bearing ( 541-889-3622 ) with my old one they checked the size and gave me new ones .
try a local bearing or pump supply house.
I do not they just used their part number 2.158Do you know what size? Thanks
Thank you, I'll try the part number.. Was it expensive?I do not they just used their part number 2.158
That wasn't the right part number.. They said it was 4" in diameter.. When I figure it out I'll post it. ThanksI do not they just used their part number 2.158
This was very helpful. Thanks you very much..Some info on our 2-piece wheels that might be helpful here.
Yes, from Hutchinson the manufacture of the rim.. Part number is P/N 50021.. Guys name is Bill Barrett.Any one know where to get 15 in o rings for the Growler ?
IMP
