Growly Steering M925a2
mzak88
36
Grand Forks, BC, Canada
Apologies in advance, I have searched the forums but with no luck. I have a 1990 BMY M925a2. Up here vehicles over 8200kg in GVW must get yearly inspections like any other heavy truck. One issue my inspector had was with the steering growl. Not sure where to start with this, anyone have any pointers?
BKubu
1,088
Gaithersburg, MD
Have you checked the fluid level? I assume so, but I had to ask. They whine a bit if they are low on fluid. If it is low, you could have leaking seals somewhere. In that case, I suggest using Lucas power steering fluid/additive. I once had a truck with such a leak and, after a couple of bottles, the seal swelled and never leaked again.
mzak88
36
Fluid level is good, appears to be motor oil. Not sure if this is a normal thing for these trucks or not. Mechanical inspector guy was concerned and is one of the "problems" he wants corrected before it gets a pass.
simp5782
Feo, Fuerte y Formal
9,261
Mason, TN
Motor oil was standard for logistics in the military. Drain and flush and use dextron iii atf. The growl will subside. Dextron has anti wear additives in it.
mzak88
36
What would be the best method to drain and flush? Any simple way? Or just disconnecting stuff and letting her drip?
