- 1,811
- 1,510
- 113
- Orlando, FL
is it just decorative? If so try searching for Nut caps?...
Does anyone know what these little silver shields that go over the nuts are called?
It's not decorative in this use. It fits over the nut, making it a little wider, so that when it's sitting in the seat track it fits more closely. This lets the seat track act as the "wrench" to hold the nut, while you install the bolt.is it just decorative? If so try searching for Nut caps?
No armrests at all, fixed or pull-up.Someone said those have a pull-up armrest.
Is that true?
Found themIt's not decorative in this use. It fits over the nut, ...
Very clever. So they are a "push nut" for a larger size screw, that just happens to fit over this regular 5/16" nut.Found them
McMaster-Carr
McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.www.mcmaster.com
