- 14,603
- 4,674
- 113
- Buchanan, GA
Well I've been wondering where my coolant has been going. It appears I've got a leak. The truck starts and runs fine, but the engine oil is cloudy, not milkshake, but it appears black/gray/greenish. Looking at a gasket online and the surfaces, I'd think the leak is probably going back into the opening for the pushrods. Tomorrow if I get home in time, I'm going to pop the valve covers and see if I can find anything. I also found that the hoses between the intake manifold and the one behind the oil filters were leaking. So I tightened the clamps on them.
Has anyone had a head gasket failure of this nature? From all the searches I've done people typically have had failures that caused oil leaks outside of the engine or combustion leaks.
I've also seen Clinto's head freeze plug issue. Are there any other freeze plugs located under the valve covers?
