guess what happend today
GM-M1008
Weatherly, PA
Well i came home from school and i was looking around the web site. I asked my dad if he heard any thing about my truck. He said no (he was lying ) . A few minutes later my mom says look whats coming up the road...and sure enough it was my truck.
Blood_of_Tyrants
11
Lebanon, TN
Why?
no plans yet beside repainting it and straightening out the rocker and new tires
I think he means that there is no cure for green metal fever. First it is a M1008, then you "need" a matching M1009 and then you may as well get a deuce, or two, or three. While you are at it, why not get a 5 ton? And so it goes.
poppop
39
Brooklet, Ga
Lost cause now.
What hoop means is you have made the last and fatal step in this green disease. You went and bought one so now there is no return to normal and nobody can own just one. I bought one little M151A1 Jeep and now own 3 5 ton trucks. 4 Dueces, 3 m105 trailers, 1 101 trailer and a lubrication trailer. I have all I need, wait, what was that flash of green I saw in the bushes. OH, and by the way, there is no known cure.
SO, WELCOME to our world:-D:-D:-D
USAFSS-ColdWarrior
Chaplain
5,842
Why?
Do you notice what I've highlighted in your quote above - with BIG RED LETTERS :?::!::?:
This is a DEAD-GIVE-AWAY :deadhorse: that GL probably handled your truck with a forklift and therefore probably also DAMAGED THE DRIVELINE.
WARNING:
INSPECT DRIVELINE :!:
GM-M1008
Weatherly, PA
i inspected it why it was up on the air and then then crawled under it i didnt see anything wrong with it ..drive shaft it strait no cracks in tcase or trans ...i don't think it was moved by a fork left because the was only one spot thats dented the rocker (its no the bad) the rocker is pushed in from the side and there is a long scrape make coming from it like it slid into something or something hit it while in motion ...if you look close enough in the pick u will see the scrap mark..i will tri to take better pic
dstang97
30
Clover, SC
looks nice. You may want to check to make sure all of your gauges are working correctly. It could be the picture but they should all flash when you turn the key.
lindyp38
ulster county ny
congrats......visually check to see if u have glow plug control card.......and before u start using it...too much.....do the DOGHEAD starter relay mod........
good luck.......
lindyp38
ulster county ny
my driveshaft was bent....i have since had a new one made....and i had the passenger door and fender replaced....they were badly mauled...by a forklift........
