- 10,854
- 729
- 113
- Front Royal, VA
Got a minute today to work on Gumby (weekend with my daughter, no serious time to wrench). After installing the new coil, and checking all the plug wire connections, a spurt of starting fluid and a short prayer, and....
wrrrrrrrrrrr...CHUGrrrrrrrrrCHUGrrCHUGrrrrrrrrrrrCHUG CHUG CHUG CHUG CHUG CHUG CHUG....
Well, my bad, I had to stop running it after 5 seconds because there was oil spraying all over the driver's side of the block. Thought it was bad news, then found I just failed to torque down the oil filter, I had only finger tightened it. So, at least the left side of the engine is now rust-proofed!
So, to make a long story short, she fired,and she ran surprisingly smoothly for a 40-yr old engine that has been sitting for 10-15 years.
Another MV engine saved!
