Gunner's platform/Stand
jpinst
Hong Kong/Long Beach
Does anybody have any idea on where to mount the gunner's platform in a 1025 HMMWV?
All I really need to know is how to measure off the hols that I need to drill in the body.
Thanks in advance!!
Iron7
San Antonio/TX
Sir, may I ask for a picture to better answer your question? There's a couple types of weapon mounts. If yours is the type that bolts to the deck, it can be mounted either in the rear cargo area or the center, will help you more with pics or at least the nomenclature.
86humv
545
Texas
Dean...The one I have will mount to existing holes if mounted in the center....or put it in the back area and you will need to drill holes, 2 ea. I think. Mine is not mounted, just fit checked a year ago.
Iron7
San Antonio/TX
I concur. I'm pretty sure what mount you're describing. We did the same thing by using the two existing holes and drilling the additional two. Just be sure to look underneath to be sure you can safely put the bolt where you need to meaning, check for wiring, braces and anything else in the way.
