H4 Headlight Conversion
jdoktor83
westhampton, ma
Powerstroken: I did my 24v hid conversion to my m35a3. It turned out great. I believe they are better or brighter than the LED style. I got my kit off ebay. Type in 24v bixenon HID. All the ballasts and high/low beam module fit under the a3's light shroud. I had to lengthen the wire to the other headlight because of the longer distance. Also pull a wire from the + on the battery to the ballast. The hids I got were 8-32v I believe.
Jeeper10
Freeville NY
Just some notes on doing the headlight H4 conversion
I just completed my headlight conversion to H4 headlights. Very simple process and I thought I'd just share what I learned in hopes it helps out others a bit.
Dorman 84790 hd harness (autozone) they had a couple choices and I went with a heavy duty one as were dealing with a 24V system and I'm using 70/75W bulbs.
7" universal H4 housing and bulbs
Green wire to 18 wire Red Wire to 17 wire
Black wire to 91 wire
I spliced the above together, and used heat shrink tubing
The whole thing took about 20 minutes. The attached image shows the new lamp on the driver side in the original one on the passenger side. I'm looking forward to driving it at night and see what a difference there is.
jbayer
10
St. Aug., FL/ McGrady, NC
Looks Good Jeeper10.
Definetely brighter. Have a PN for the housings? Are the lens glass or plastic? Are the housing's plastic, or metal.
I'd like to do this mod too.
Jeeper10
Freeville NY
they are glass with metal housing.
Purchased from octane lighting on eBay, but there are a variety available.
gottaluvit
Thats the exact ones I got. One of the indents for the three alignment "humps" were off a hair, but a little file work fixed that. The original bulbs that came with the octane housings won't last long on vibration, but I did have excessive vibration on driver's side which I corrected. Replacement bulbs are cheap and you can get just about any brand you like. I got nib Volvo bulbs at $21.60/3 ea. off ebay recently off of qpd316. He has two left. I just checked. Just get to the seller and search "volvo h4".
rustystud
3,374
Woodinville, Washington
Just remember to use "ceramic" pigtails. This light makes a lot of heat. I melted my first ones, then went and bought the ceramic plug and they have worked great ever since.
gottaluvit
Funny thing I did was not realize the pigtails I bought were ceramic and I broke one. Oops. Then I unknowingly ordered one from a seller that was in China and it took like six weeks to get to me. Glad I don't drive mine in the dark, except at Winter when dark comes in the afternoon.
