Halfshaft bolts
Ang2gna
Maine
Can someone please tell me the size and hardness of the bolts that connect to the rotor? I replaced my left front halfshaft today and I want to replace them. Do I also need to replace the bolt that attaches it to the hub? Last one, I promise. The bolts on the rotor only had the split lock washer on them. I ordered nords because I swear I remember reading somewhere to use them instead. Am I right? Thanks in advance!
BLK HMMWV
497
Pasadena California
The 6 bolts used to hold the half shaft to the rotor are metric they get the Nordloc's. The single bolt that holds the splined end into the hub is a standard not metric bolt that gets a split washer type lock washer.
Make sure you follow the torque specs and use lock tight
I would strongly recommend you buy the TM's related to your MV or use the TM section hear on SS.
Here is another source of information for you
http://www.flashoffroad.com/Maintenance/halfshaft/halfshaft_replace.htm
While it is geared more to the civi version allot of good info relates to HMMWV as well
http://www.flashoffroad.com/humdefault.htm
Ang2gna
Maine
Thanks everyone! I do have the TMs. I don't know why I typed that I didn't know the bolt size because I had that, I just didn't know the hardness of the bolt. I didn't want to buy a bolt that would end up snapping. Thanks for the answer to the hardness. I think next time I am going to buy the bolts from a vendor as opposed to searching for them in the store.
Retiredwarhorses
4,174
Brentwood, Calif
those bolts can only be purchased from distributors. The hardware stores don't stock that head size.
