Danger Ranger
- 24
- 0
- Roland, IA
Cool! Anymore updates? When is paint-day?
As soon as the weather cooperates I will pressure wash the deuce, do some sanding, and spot prime. Once the primer cures the paint will go on. Maybe by mid February?Cool! Anymore updates? When is paint-day?
Hank, thanks for the heads up on the brush trucks.Hank , check out Long Island brush trucks... Hanks trucks
Yes, I still plan on the external roll cage. It will somehow tie into the interior to provide harness attachment points and new seat anchor points in the event of a rollover. It will be 2" DOM tube 0.188 wall for the main hoops and 0.120 wall for the rest of the cage.The bars for the brush trucks look awesome. Is this still on your wish list?
Adrian...I bought the adapter plug from Erick's Military Surplus. It's easy to install and it works great. I think it costs about $83 dollars. I also discovered that my flasher had water inside it's mil connector. That resulted in front and rears turn signals that wouldn't blink even after the adapter was installed. So, between the adapter and a dry flasher connection my turn signals now work great.There is an adapter plug that goes behind the multi switch that allows the markers to work correctly. Maybe someone will have more info about it. It was about $90 if I remember correctly.
Tom, my deuce lights worked fine stock. I was concerned when I upgraded to front and rear LED lights, but they still flashed correctly. Since the deuce doesn't have parking lights for driving I jumpered the wires to provide parking lights while driving. The jumper mod does illuminate the LED front lights, but when I switch either side with the turn signal switch the LED brightens, but does not flash. I would think it could be flasher related. I've always wondered why the factory flasher worked with the new LED lights.hank, you jumped the correct wires and they have nothing at all to do with the turn signals, that is only the side markers. the front turns are i believe a separet bulb. if your rears flash your flasher is good.
