Hard to shift OUT of 3rd.
SMOKEWAGON66
21
California
Well, the military put gear oil in everything, so I think you would have been fine. Some say the oil makes it too easy to shift and they sometimes bump the reverse gear when they shift to second gear.
now are you talkin bout the A3? 'cuz i thought, and checked/double checked in my TM that GO was used in the manual shift trannys....OE/HDO would be too thin....
Which are you referring to? 30w in the trannys for A3's or?
gimpyrobb
dumpsterlandingfromorbit!
27,786
761
Cincy Ohio
You are looking in the army book. The manufacturer states 30wt.
KsM715
142
St George Ks
A2
Yep, after searching and reading a bunch of differing opinions( http://www.steelsoldiers.com/deuce/47921-gl-1-gear-oil-alternative.html ) I decided to go with SAE30. I wanted 40w but couldnt find it locally and I will be draining it and refilling again soon so I went with 30.
