hard to turn at low speed at times
cpenni
charlotte nc
hi all i have been looking at threads trying to find out why at times when i turn sharp forward or backward the steering binds like the front axle is engaging then it pops and all is fine. it seems to only do it if i turn hard one way from a stop. i have a 1968 M35a2 thanks.
Scar59
41
Mt. Eden, KY
Sounds like the front axle is engaged, is the truck equipped w/ an air engage switch? -or sprag?
gringeltaube
Staff Member
2,304
Montevideo/Uruguay
Most probably you have a sprag transfercase and the shift rod in between transmission and T-Case needs some maintenance/adjustment.
G.
gringeltaube
Staff Member
2,304
Montevideo/Uruguay
Yes. And here is a thread that may help you understand what that shift rod is supposed to do... after a good service and adjustment.
G.
gimpyrobb
dumpsterlandingfromorbit!
27,785
748
Cincy Ohio
It could be that you have u-joint issues too. My money is on the T-case, but I figured I'd let you know there is other things if adjusting your linkage does not remedy the problem.
If you still have issues, post up. There is a couple styles of joints in these axles.
