Hard Top Install/Removal?
01GRANDER
56
Alabama
Hey,
I was wondering how hard it is to remove and reinstall the hardtop? I really want the ability to convert to a convertible but I definitely like the idea of never having to replace the top and just having a hardtop. I would assume there is less noise and you could coat the underside with a noise barrier.
I know that you can get a relatively cheap top from Breton but if removal isn’t horrible, I think I’d rather go ahead and buy the hardtop.
01GRANDER
56
Alabama
Action explained that the original top uses different parts which I don’t have. I guess that leaves me with the aluminum version, I think you have to modify a few things but can use all the soft top components. I’ll just have to see if there is an easy way to remove it, it is aluminum so it wouldn’t be very heavy.
Gamble
375
Los Angeles, CA
Hey,
Who or What is Breton?
NVM I think I found it.
TOBASH
3,946
Brooklyn, NY
Are there Aluminum tops with the turret hole already cut out?
I'm thinking of swapping mine out due to rust potential as I live by the beach
TOBASH
3,946
Brooklyn, NY
yes, any newer M11XX truck uses aluminum roof....prepare to pay out the yazoo Though.
Thanks Steve, but wouldn't that top require modifications to fit my 1987 M1025A1?
Are there any aftermarket companies that make these?
I'm looking for a fun truck, not a FMV show winner, so I'm willing to trade off OEM for something that looks close.
Retiredwarhorses
4,603
Brentwood, Calif
No modification at all.....you will just need all the correct parts on the B-pillar. And if you want the turret, you will need slewing ring....so figure about $7500
Retiredwarhorses
4,603
Brentwood, Calif
I have a turret/mechanical turret. So am I correct to assume I will only need to purchase an Aluminum top?
Top view of my rig images attached.
no, you will need everything I pointed out, you cannot just drop the old Turret into the new roof without the slewing ring, the hole is much larger and the ring reduces the hole down as well as acts as part of the roof support.
what you won’t need is the current turret roof support, that gets removed.
