Hard top seals?
ranchhopper
136
south elgin illinois
Use camper tape it works much better than the original seals the bead on the original seal directs rainwater toward the seam instead of away from it making more rust issues.
135gmc
St Paul/MN
3M makes some closed-cell neoprene foam tape with some heavy duty adhesive. It's available from Grainger. Make sure that whatever you use is closed cell - open cell will instlate OK, but water will run through it.
dikwks
Suffolk VA
Just R&Red my top a couple of weeks ago to fix corrosion issues caused by the old seal. Went back with the flat foam from Lowe's. All of the cancer was caused by the lack of drainage from the old seal.
