Hardtop insulation replacement?
goldneagle
931
Slidell, LA
Actually I used 3 layers of the Aluminum Bubble Wrap Insulation sold by Home Depot. The 2 foot wide rolls work out perfect. You can always paint over the insulation if you don't like the aluminum look. I used the Scotch 77 spray glue to tack it in place.
Some people use the sleeping bag under-mats to replace the old foam. It's already green too.
tokarev
Safety Harbor Florida
I didnt think of the sleeping mat material - my dad might even have some laying around from an old surplus buy. The db engineering has some neat stuff too.
Just spoke with my dad - BINGO he has the mats !! - we will give that a try with pics to follow.
Question - suggestion for glue brand?
runk
65
Houston, TX
If the sleeping mats are stiff enough (I used 1 layer of the Mylar bubble wrap, and then ~1" thick foam exercise matting), the original metal straps and center board holds the insulation in place fine without any glue. I did need slightly longer screws, though.
steelandcanvas
85
Southwestern Idaho
I'm interested in replacing my insulation, how did the sleeping mat material work out? Got photos?
DIndFab
Ohio
McMaster carr has 1" thick foam that's adhesive on the back side that I used for a tractor headliner. It was an exact match to what was in there.
