Harmonic Balancer installer
20,781
Tomorrow I should get my bolt to help me install the balancer. I want to rotate the crank 1/4 turn so the key in on top and visible. It's on the passenger side so need to turn it CW standing in front looking at it.
Can I just do it slowly or something special I need to do first like pull or loosen the injectors to relieve compression? Fuel has been shut off since last run about 2 months ago. No oil or water in it at present. Been freezing at night for about a week.
Turned slowly, that should work and not be a problem.
Also going to suggest using the rear tire to rotate it if you have a manual transmission. (jacked up of course)
