Has Anyone Altered the MEP 831 to make it super quiet, like 58 dbA or less?
ECS
50
Florida
Has Anyone Altered the MEP 831 to make it super quiet?
There is a plate in front of the exhaust exit, and I was thinking of adding a second muffler to make it extra quiet; or remove the main muffler and pipe it to a larger muffler.
Has anyone successfully done this or will it mess up the back pressure?
Right now I think it is at about 70 dbA, and was kind of hoping to get it down to 58 dbA ot lower.
Coug
4,239
Olympia/WA
It is unlikely you will get the sound much lower just going for the exhaust pipe. I know in the civilian side of things people have run exhaust pipes into buchets of water and all sorts of other things, but the exhaust is not the only source of noise.
The mechanical sounds and the intake are also a large portion of the noise from any generator set, so about the only way you will get a generator that quiet (particularly a diesel unit) is to build a secondary enclosure on the outside, being careful to allow plenty of airflow through the unit while at the same time channeling it in such a way that the mechanical noises don't escape.
Using a secondary exhaust muffler might get you a few decibels, but still going to be in the upper 60's most likely.
