Erik Jenkinson
- 9
- 18
- Alpharetta GA
Nope the last four! I started at the back! A couple in the front to hold it up but not those four!let me guess you found out about the oil pan gasket just as you went to put the first few bolts in lol....
I like to RTV the gasket to the pan prior to install. This makes sure all the bolt holes are lined up.Nope the last four! I started at the back! A couple in the front to hold it up but not those four!
I did but did not see the misaligned holes! I never thought to look for symmetry....I like to RTV the gasket to the pan prior to install. This makes sure all the bolt holes are lined up.
The one auto zone carries is cheap wire with a cork screw end.... There is a kit you can buy at most autoparts stores for installing rope seals it contains a cable with a chinese finger at the end for snaking them around a crank.
Denny
