Has anyone here used this tool?
319
Lieutenant
57
Michigan
I have the OTC 7249 (of which HF's supplier copied). Works great on ball joints and u-joints. Also works on truck brake shoe anchor pins. OTC has a number of other adapters available for different vehicles.
Be sure to keep the screw lubricated!!
whyme
angola ny
use one just like it all the time on vehicles around the house, do a lot of work for friends and family. ive never had the pleasure of using a press but then id hate to have to remove a control arm just to press the ball joint out. auto zone has them on their loner tool program so i just get it when i need it. def a worthwhile tool and does the job. but yeah i dont think its gonna be much use on larger trucks if thats your intent.
cornrichard
Galesburg, IL
I have one of those. I also used it for my hub flip and it was good as gold. When I tried to use it for the ujoint in my 3/4 ton dodge van, it was too small. The first one I got was a bad casting and the end collapsed on itself. They took it back and gave me a new one.
Dave Kay
29
Kingman AZ
did you look at the 22 reviews on HF's site?
Yes I did look at the reviews but as one person pointed out, some folks may not be using it properly and they have problems. Seems split 50/50 whether this is good for intended use. Mainly I'm wanting to redo 2 drivelines for 3/4 and 1-ton light trucks, nothing heavy as of yet. Possibly more/different vehicles in the future.
Popping Ball joints would be a plus but has anyone redone their king-pin bushings on an M1008?
Dave Kay
29
Kingman AZ
... I tried to use it for the ujoint in my 3/4 ton dodge van, it was too small. The first one I got was a bad casting and the end collapsed on itself. They took it back and gave me a new one.
Too small? You don't say! what size joints--- 1350's?
m16ty
211
Dickson,TN
I will say that I've not had any luck with Harbor Freight tools that do pulling, pressing, or impact tools (such as punches and chisels). They always bend or break.
I always just use a vice and an assortment of different size sockets to install u-joints. A torch and a hammer works great for removing old joints (cut the cross and then drive out the cups).
ODdave
lansing michigan
its works, but keep in mind it says CHINA in huge letters on the side for a reason. I had one i used ALOT and it bent. got another and it bent.......Bought an OTC......hasent bent.
My input for what its worth...
ODdave
lansing michigan
completly wrong tool for dana 60 "king pins"
dodgedougak
Joseph, OR
I have been underwhelmed by anything at HF. I did buy some cleaning supplies and such that were OK, but I don't think I would buy another tool there.
m816Buch
Morganfield,KY
otc tool is quit abit stronger than the hf tool.........pricier too........but you don't have to worry about it breaking or bending unless you don't have "tool savy"
mbc
Weaverville N.C
I have one I bought from advance auto. Don,t remember the brand but I,ve used it for balljoints and Ujoint in 1/2 and 3/4 ton trucks with succes. I have also used it to remove torsion bars in chevy trucks. Not the correct tool for the job. But it worked.
skinnedknuckles
Janesville Wisconsin
I use the OTC 7249 . I've seen it flex quite a bit when taking out stubborn rusted in brake anchor pins on semis. It can get scary when its flexing and then breaking those pins loose.... BANG ... I don't think I would trust those cheap copies from HF. Too dang close to my fingers arms and other body parts to trust Chinese iron on staying together. The OTC tool might cost more initially but then a trip to the ER to remove steel splinters from cheap Chinese junk costs more . Just my2cents
Paul in Janesville, Wis
onegmjack
Kingsport TN
I have a new OTC kit,wore my old one out.Will work for a lot of different thinks,mainly for balljoints.I pressed out kingpins in 40 Chevy car.Seen people use impacts on them but last longer using hand tools.
hole
Alta Loma , Ca.
I picked one up from HF to do the ball joints on my CJ a while back, worked fine for me. Haven't tried it on a u-joint yet.
