Has anyone put casters on their 802 or 803?
m32825
173
Central Florida
Demoh,
Thanks for the pictures. This is the direction I'm going, because it's "welding season" in Florida!
:beer:
Are those the 6" or 8" wheels?
-- Carl
Demoh
26
St Pete, FL
6 inch, I didnt want the center of gravity too high.
https://www.northerntool.com/shop/tools/product_200660391_200660391
Oh and the price went back down, now is the time to buy them. (they sometimes hover around $45-$50 each)
And indeed it is. Need to get my welder back together soon.
BTW the metal wheel casters are the best. No caster lasts forever, however when the poly or rubber falls off, the caster becomes more desirable because it doesnt have anyway else to fail. An old-timer explained this to me when I said "oh, I dont want those casters because the rubber came off".... Now that I am older and wiser sometimes I am half tempted to just shave off the "expendable" part of the caster so I have something I wont have to deal with down the road.
Miami, FL
Has anyone thought about or installed pneumatic casters so they can be rolled about over rougher terrain than concrete floors? While I have mine currently fixed to the trailer it came with, I am thinking about a smaller rollable version with something other than HMMMV wheels and tires.
I think the bolt pattern is a trailer tire I don’t know to much about bolt patterns but I had seen a mep 893a at Walmart with trailer rims and tires
Demoh
26
St Pete, FL
8 lug GM or Ford wheels will work I believe. Easy to find some used 16" steel wheels on Craigslist or Facebook .
8x6.5 is the bolt pattern for the trailers that use the hmmwv wheels. Dont get 99-up ford 8 lug which would be 8x170, 8x200 or 8x225.... They really need to stick to something. Actually E series vans used 8x6.5 because my 2006 has that bolt pattern. Ive graduated to medium duty recently but the ford 10 lug is still not "industry" standard.
I actually have a set of 4 8x6.5 aluminum off that van that I need to get rid of (didnt have the heart to scrap them)... I may have to test fit to see if the clearance for the drum works with those. I dont see why it wouldnt.
One point, I think if there were pneumatic casters you would have so much rolling resistance it would be very hard to push/pull unless you aired those tires up well past their max. Yes running over a zip tie will no longer bring you to a halt, but my 140lb self with a running start probably wouldnt be able to start it rolling on soft casters.
116
Miami, FL
I picked up my set today, they were shipped to the local store. When the guy rolled them up front on a cart all of the people in line did a double-take and started talking amongst themselves. These babies do not disappoint!
:beer:
How did you mount them any pics
Farmitall
280
Eubank, KY
Good setup!
Just so you know, that steel on aluminum combination will corrode over time because of dissimilarity of metals.
The bolt holes will also develop corrosion and elongate. Adding a coating of Noalox will slow down or eliminate the corrosion.
jcollings
422
Jupiter/FL
just so you know if you look close see there's a small thin piece of rubber that protects the aluminum from the steel
Sent from my SAMSUNG-SGH-I317 using Tapatalk
jcollings
422
Jupiter/FL
It actually looks like a shadow on that piece of metal so it is very hard to determine that it's a thin piece of rubber there
