Has this happened to anyone before?
Lex_Ordo
Long Island, NY
While driving last night around town, I started to smell anti-freeze.
Hmm?
Then I started to see it in the cab.
Hmm? Wow?
I stopped opened the small Left side hood, and saw that I was leaking coolant from the hose that connects up to the oil cooler.
Hmm? Did I blow a hole in a new hose? Maybe?
Drove home and shut her down before she got to 200 degrees, and washed the coolant off everything for better inspection.
I think from what I'm observing the oil cooler pipe that the water pump hose and the oli cooler hose connect to, shifted forward, pulling the oil cooler hose just far enough off the oil cooler that it found a way to relieve pressure, and started to leak coolant.
Under high pressure, it sprayed all over the inside of the engine compartment and dripped into the cab through the steering column hole.
I have to wait a few days to work on the truck, so I'll know more on Monday.
gimpyrobb
dumpsterlandingfromorbit!
27,787
778
Cincy Ohio
Along with the brakes, it is a good idea to inspect replace all the hoses on a truck you don't know the history of. Sounds like the hose got old and "let go".
Lex_Ordo
Long Island, NY
New radiator, new hoses, new cap, flushed and re-filled with fresh coolant, new thermostat, everything that was needed to replace was done. I also did all the rubber brake lines, and E-brake cable & shoes.
I guess every truck is a bit different. No worries. I'm sure it will fix right up when I get to it next week.
gimpyrobb
27,787
778
Cincy Ohio
When I did the hoses on the 109, I didn't get the band/clamp behind the metal lip and it would leak/spray coolant. Maybe just checking/adjusting will take care of the problem.
Lex_Ordo
Long Island, NY
Yep, everything is better now!
I went through while I had a minute to myself, and tightened up all the hose clamps, and the problem was that the hoses have shrunk a bit and the clamps weren't as tight as they were when I first changed them.
Re-positioned the tube for the oil cooler, and re-tightened the hose.
I just ran the truck to get it to temperature, and it ran smooth and dry at 175.
looks like it was an easy fix this time.
Whew!
3,148
7 psi?
Pretty sure thats what I saw on the inside of the radiator cap, not high pressure, but enough to spray out I suppose?
Block/WP pressure will be close to 20-25 PSI at rated RPM.
