Hatz diesel
dalton92
TN
I've got two hatz single cylinder Diesel engines, both brand new and both have melted the air filters, under operation of the operators I might add, I have not seen this before and looking for some advice.
Dalton
steelypip
68
Charlottesville, VA
If it's like everything else I've ever seen, it's a sign that somebody ran the engine backward. Some diesels will do that. Biggest concern is that they didn't shut it down before the bearings starved for oil because the pump (if any) was running backward.
dalton92
TN
How would it run backwards? I have never heard of this, but seems possible, I doubt it has a oil pump as it's single cylinder air cooled, probably like a flicker on the bottom of the rod but not 100%
goldneagle
977
Slidell, LA
I had one of those engines in my MC-2A air compressor. There was a large 12" fan that blew cool air to keep the components inside the unit cool. It also had an oil cooler.
RIrvin
Kirkwood MO
If this is a 1B30 family Hatz type engine, the damage may be from operators attempting to start engine with aid of gasoline vapors or other aid inserted in the dry type air cleaner space.
dalton92
TN
Thanks this seems plausible, there is also a heating element inside the intake, any chance if left on could this damage the rubber on the filter?
RIrvin
Kirkwood MO
The Hatz I have seen were key started and only applied any preheat to "glow plug" in air inlet for very short period. Do these units have a battery (12v or 24V)power source? Are they slave started? I'd suspect some human error as whisky357 mentions. I have some manuals / documents on 1B30 if helpful.
dalton92
TN
Yes it's slave started with 24v, with pull start aswell, but now I'm doubting the preheat theory because they were only pull starting them
steelypip
68
Charlottesville, VA
What were the engines attached to? Is there some possibility that they could have been bogged to stalling? That's usually how you get the 'running backward' problem.
