Have any of you weighed your modified CUCV?
79Vette
173
Los Angeles/CA
My 1009 is a heavy pig. I knew that. I haul a lot of stuff around in it on the regular.
33x12.50r15 tires and a full size spare, huge steel plate bumpers front and rear, winch up front, full 27 gallon fuel tank, full 10 gallon water tank, a big steel truss welded on the rear axle, 24v fridge and a camp stove on a slide out, tool bags, recovery gear, solar panels, 1.5 HP of air compressors, SM465/NP205, 6.2 diesel with 6.5 turbo, a small DC welder, 2kw inverter, and a small duffle bag with a sleeping bag and some minimalist camping gear.
Anyway, out of curiosity I took it to the truck scale today and they weighed it. Turns out it's way heavier than I expected at 3280 lb in front and 3520 in back, 6800 lbs total. If I put in 3 more people (550-600 lbs) and food and camping gear for 4 people for a long weekend (200-300 lbs depending what we bring) all of a sudden my Blazer would be pushing 7700 lbs...
I was stunned how heavy it is, but it's a certified scale so I'm sure they are right. Have any of you with built out CUCVs had them weighed? Does this seem crazy to you?
chevymike
485
San Diego, CA
I weighed my gutted box M1010 and it came in at 6220. Once I remove the A/C off the box, that drops another 200 lbs. That was stock with 255/85-16 Toyo M/T's on aluminum rims, full tank of fuel.
LT67
514
Bowdon, GA
My M1008 with 35in Toyo MT on OEM style 16x8 steel wheels, whale tail steel rear bumper w/Warn xd9000 and a full tank was close to 6.1k lbs
dezertdemond
So Cal
Here's the details on mine. I was also surprised at how heavy it is.
Vehicle specs and weights:
1984 K5 Blazer CUCV M1009
Weighed with full camping gear, water and fuel, but only 1 person inside.
Total weight- 7300lbs
Front axle weight- 3300lbs
Rear axle weight- 4000lbs
6.2L Detroit Diesel w/ turbo
Turbo 400 trans
NP208
GM Dana 60 front axle
GM 14 bolt FF rear axle with drum brakes
39x13.5x17 Toyo MT’s
Modified stock front bumper with 12k winch
Roll Cage
Soft Top
Rear bumper with swinging tire carrier and 3 jerry cans
