Ridgerunner
- 6
- 0
- Holland, Mi
That's a big tank, 74 1/4 gallons worth.I stopped by a welder today and gave him dimensions of 55 wide, 24 tall, and 13 deep.
That still is SMALLER then a standard 5t single tank truck (78gal.) tank.That's a big tank, 74 1/4 gallons worth.
Judd, If you can make a trip to Baltimore, I probably can get my contact Yolanda to quote a price for both steel and 5052 aluminum.I've changed my mind on what shape I want the tank to be after doing a bit more precise measurements. I think I'm going to do a 13" tall, 13" deep, and 87" wide tank. It will still require two sheets of material, but it will be completely below the bed rails and still leave me just over 8' in the bed to put stuff. Should be a little over 60 gallons worth of capacity too.
Bottom tap is the way I'll go. I'll still use a pump, but it will be external and easily bypassed.
The biggest question still remains: steel or aluminum? I'm going to use 1/8" and steel is considerably cheaper. I might even try my hand at welding it. I'll get as much of it bent as I can so I have less welding to do. I'm strongly leaning towards steel with a fuel tank liner applied at this point unless someone gives me a strong argument to use aluminum that justifies the extra price.
What running board at the door? It's got nothing below the frame rails except axle now. The fenders are cut to the bottom of the cab and the cab is the first step from the ground. Fuel tank, tool box, and batteries are all going in the bed. It's a toy, not a daily driver.
I was thinking of doing a top tap with a dip tube and a pump for primary fuel delivery, but have a bottom tap plumbed in with a manual valve for gravity feed as a backup.
Use SS if you are going to ever run WMO or WVO. There is a higher acidity to these fuels that will eat away at Aluminum in the long run. The food grade aluminum kegs are not the same type of aluminum as tanks are made from different alloy to keep the PH setting. This is only with the tanks made from 92 to present though.
After final installation, remember to add a ground strap to prevent static build-up...Remember if using disimular metals to mount using a poly or rubber bushing or trouble will soon follow as your tank gets eaten away from corrosion.
I believe 15 1/2 gallons.So, how many gallons dose a full size keg hold?
I'm not sure but it's more than enough to give several people a headache in the morning.So, how many gallons dose a full size keg hold?
two cents? if you're mounting a tank there, and it's aluminum and brand new, you should be able to keep that puppy very clean. I'd go with a bottom tap, which would also mean you have gravity on your side for pressure. Not that we NEED a tank pump with the deuce, but every little bit helps. I'd also include a drain valve if you are going multifuel. I always thought it would be nice to drain the tank if you get one full of crap.
I'd agree with 59Apache, tank builder. Might have an idea or two as well.
