Having some Problems with a 1970 M35
jerseyjeep2003
Gloucester City NJ
TNJ Murray in Dover Delaware has the in tank fuel pumps, a bit pricey at $400, but I guess that is about average for brand new (mfg'ed in 2011). Ask me, I just replaced mine. But before popping for a new pump, check the fuse. It is located in the little rectangular cover that is bolted to the top of the tank. It has the wire coming out of it.
gimpyrobb
dumpsterlandingfromorbit!
27,786
763
Cincy Ohio
Dunno why you would go there when you can get them direct from the manufacturer for $320.
http://www.occorp.com/?page=Pumps
poppop
39
Brooklet, Ga
I have gotten several pumps running by cleaning connections. If it runs when you hit the tank then that should do the trick. One pump had a loose wire in the tank.
jimk
46
Syracuse, New York
There is a buss fuse under the cover on the tank. There is a good chance it is loose (inside or out). Any crude [in the bottom] that can get picked up empty will get picked up full.
gimpyrobb
27,786
763
Cincy Ohio
Dang!!! Wish I had found them when I was looking for a pump. But, then again, I was stuck and Murray is about a 45 minute drive from me. I'll store that one away for future reference. Thanx Gimp, you're the best.
It just amazes me that people get away with some of these prices. Wish I had known you were looking too. Not too long ago, I was selling NIB pumps for $180. Wish I had more.
highfavor1004
Eustis, Florida
update trucks running. the stupid shut off shift post a couple in a day or so. also still looking for a front drive shaft, and a set off lockers now
phil2968
Lakeland, Florida
Good to hear you have it running now. That stuck shut off cable has gotton a few folks! My phone died this evening during our talk, sorry. I should have had it charging. Maybe sixspeed will come through with that driveshaft. I will see you at the rally!
