Hazard Light Switch
408
Colo.
Granted my brain is fried from hunting all day in knee deep snow, but I can't get the hazards to switch off. Yes I read the Operator's Manual. Any help? The cover with the spring just pops out and in, but I can't get the lights off.
Rich Johnson
San Diego CA
maybe the contacts inside the switch are stuck together.
My hazards dont work when I pull the switch or push it in or whatever. And sometime my left indicator doesnt work. Its an old truck and I just live with it. I spend my time chasing the leaks.
408
Colo.
Can someone describe how it is supposed to work for reference? This is my daily driver, and I've needed the hazards a couple of times, but I'm at the point of just retardation. I need this truck without flashing right now. I just need a point of reference to troubleshoot from. I'll cut a wire if I need too, but I don't have a feel for the basic mechanism.
Sasquatch
Alaska
Basic Mechanism:
To turn on press the button in.
To turn off pull the cover out then give it a pull.
The little switch cover is pretty loose and moves in and out with doing anything (not sure why it's even there beside to prevent someone from bumping it accidently). My actual switch is very stiff and needs a good tug to get them to turn off.
If you cut a wire you might lose your turn signals.
34
Portland Oregon
carefully take apart the Turn signal system and carefully separate the contacts in the switch .
If you are unable then buy a new turn signal switch there quite easy not expensive .
I hooked up my I.C.E Unit and it showed me my signal was burnt so I replaced it Good luck to you
duchiem1009
tampa florida
You do not want to cut the wires you will lose turn signals and brake lights as all run through the turn signal switch behind the steering wheel. sometimes you need to push the button for the hazzard button in and out a few times to get the switch back to the netural postition. if I remember right the plastic turn signal cams are about $8-10. If you get the whole assembly ,which requires you to fish the wires through the steering column, are about $23. It's been awhile since I've had to replace one but those will give you a ballpark figure.
408
Colo.
I'll give it a go. Thanks much. Another brutal day of hunting. 4:30 - 6:30.
Abnormally strong tug worked. Thanks.
