hazard switch stuck on
cagosti
mich
well I pushed it in while testing trailer lights.
the push button has seperated from the switch I think.
any way to disable without terring the whole steering column down?
Charles
m1008a1
Tow4
622
Orlando, FL
Pull the flasher relay on the fuse block. It's the top left round can if I remember correctly.
wallew
Yeah, that's the only way for a temporary fix.
But replacing it will involve removing the steering wheel. IT'S NOT THAT TOUGH. Just make sure the front wheels are straight before you remove the steering wheel and the brakes are set.
Then remove the steering wheel with a puller and replace the switch. If you do not have a steering wheel puller, your local parts house SHOULD loan it to you. You will have to give them a deposit, but as long as you don't break it, it should be free.
Warthog
227
OKC, OK
Sometime you can take a drywall screw and pull the switch back out. It will need to be replaced at some point.
cagosti
mich
flasher relay
with out the top relay I loose turn signals,
I going to pull whats left of the stud out and try to
move the switch with a small pic.
