Head and turbo manifold installation...a different way!
llong66
kokomo, In
Hello! I have been working towards today over the last few months, working out several problems along the way. Today was the day my buddy was able to come over and help me get the PS head and turbo exhaust manifold installed.
I have read all the posts I could find in preparation for installing my turbo and the one common problem has been installing the turbo exhaust manifold. What I did will not work for every one as I had the head removed chasing other issues.
What I did was to simply bolt the head and manifold together in the garage and install them as a unit. We removed the hood to make this easier and unless your a champion wt lifter, you will need an assistant. The whole process worked perfectly! Now that it is on, I can see what I nitemare it could be installing that manifold with the head on the motor and in the truck!
For those of you that have done this before, thank you sooo much for your help and posts, for those yet to do it, if you have the head removed anyway, this is the way to go!!
Good luck and thanks to all!
Greg
llong66
kokomo, In
I didn't think I needed pics, I just bolted the exhaust manifold to the head and set it on the motor in the truck...what would you like a pic of?
True Knight
171
San Pedro, CA
:funny:
I think he wants a pic of you modeling with your turbo/manifold/head combo! Ha ha
BTW: thanks for the tip. Maybe I'll be able to use it someday if I ever get around to installing the turbo.
llong66
kokomo, In
Would you think I should wear my gf camo bikini and keep with the theme or go w hot pink or yellow and kinda do a mix thing ;)
