Head board crane
bill2444
cheboygan/mi
keep an eye out on craigslist, I just scored an econo ton for 200 bucks. All it needed was a paint job-but it needed to be green anyways.
gimpyrobb
dumpsterlandingfromorbit!
27,791
787
Cincy Ohio
So Its mounted and doesn't budge. I did make a top support for it, not sure if I'll put it on or not. Now I need to remember where I put that stupid 2klb winch I got for it! It will be mounted to the top of the post. The top tube is 30" from the back side of the 90*, with the extension all the way in it reaches 54", and extended its 73ish.
gimpyrobb
27,791
787
Cincy Ohio
Tried it out on Friday lifting an XML on a hemtt rim. It handled it ok, but the bed flexed a little. The base of the crane is too small. Not sure if I want to put a plate between the crane and the top of the bed, or if I want to weld the bottom plate in place. I will have to update the thread with my fix later on.
Speddmon
Blind squirrel rehabiltator
32
Cambridge, Ohio
It looks good now, but I can see it bending up like a pretzel during the next rollover
islandguydon
787
Michigan
If you have a little flex and your only mounted to the bed I would weld an upper support structure to the top of the deuce box or 4"x1/4" angle iron horizontal to the box back. That should cure the flex. Some peoples ingenuity around here is amazing.:)
KsM715
142
St George Ks
Has anyone seen or have a source for the chain fall for these Davits? According to BII each truck is supposed to have one but I have yet to a pic of one in use.
LanceRobson
220
Pinnacle, Stokes County, NC
Has anyone considered cutting down a 2-ton engine hoist and mounting it on a pivoting base? Good used engine hoists can be had for $100-150 fairly often. Add a chain fall or cable hoist and you'd be all set.
Any thoughts?
Lance
LanceRobson
220
I've seen them Gimpy but they aren't anywhere near as stout. For a small crane though I guess I'd likely only need enough to hoist tires and other than that the heaviest thing I'd pick with it would likely be a 560 pound welder/generator.
Will you be at Aberdeen?
Lance
gimpyrobb
27,791
787
Cincy Ohio
Well, we have yet ANOTHER installment for this thread!
I just brought home a Ruger hydraulic bed crane. I really wanted to find a small Hiab K-boom like what we saw at Haspin, but I could not find one. After some searching I found this at a reasonable price. :whistle:
1,193
Is that a wheelchair lift ? :gimp:
tm america
25
merrillville in
Looks nice how much will it lift?Not sure why you need it i like your other method.....Flip truck on its side then roll items in the bed and flip truck back over and go?
gimpyrobb
27,791
787
Cincy Ohio
Never thought about that, maybe my medical insurance will pay for it!
I like that method too, but I can't afford to keep Stretch 5mins from my truck at all times. I needed another option.
George, on a side note, I might have a pattern for you to start making a new product to sell. How thick of material will your plasma-cam cut?
