Head gasket repair walk through - go to post #31!
Diecorpse
Grand Island, Nebraska
Head gasket. . Replacong the one on my m35 with the multifuel. I have been taking lots of photos as I go. I will upload them when finished. Also I talked to a mechanic at D and D equipment ( great place to go for repairs and modifications for your truck, located in Big Rapids, MI) and he will try to email me step by step instructions for head gasket replacement from a Hercules repair manual. When I get that, I will either try to upload it for all to see or will find a way for everybody to access it. So far I have spent about five to six hpur and I have the heads loosend but I need a couple tools to remove the exhast manifold and the he
ad bolts on the side by the fuel injector. I wish anybody who does it themselves the best of luck.
Diecorpse
Note: For someone who hadn't done a head gasket yet, I can give a list of some of the tools required.
1/2 drive rachet
9/16 socket
11/16 socket
7/8 socket
11/16 wrench with offset closed end
3/4 ratchet for head bolts
Small and large regular screwdriver
Extensions short and long for 1/2 drive
Containers for bolt seperation
Penetrating oil
Lots and lots of patience, music, and smokes!!
frank8003
4,988
Ft. Lauderdale, Florida
Correct, no workie, and post is only eight years old.
We all wish it could be saved.
I did read how to get to the original link but I have now forgotten, I got the CRS.
cattlerepairman
3,482
NORTH (Canada)
cattlerepairman
3,482
NORTH (Canada)
  1. https://www.steelsoldiers.com/showt...t-repair-walk-through-collection-of-info-2018
  1. https://www.steelsoldiers.com/showthread.php?1989-head-gasket-leak.html?highlight=head+gasket+leak
  2. https://www.steelsoldiers.com/showt...et-what-else-check.html?highlight=head+gasket
  3. https://www.steelsoldiers.com/showt...-life-head-gaskets.html?highlight=head+gasket
  4. https://www.steelsoldiers.com/showt...ead-gasket-problem.html?highlight=head+gasket
  5. https://www.steelsoldiers.com/showt...-oil-leak-question.html?highlight=head+gasket
  6. https://www.steelsoldiers.com/showthread.php?44735-multifuel-head-gaskets.html?highlight=head+gasket
  7. https://www.steelsoldiers.com/showthread.php?43935-bad-head-gasket.html?highlight=head+gasket
  8. https://www.steelsoldiers.com/showt...ke-need-assistance.html?highlight=head+gasket
  9. https://www.steelsoldiers.com/showthread.php?40801-blown-head-gasket.html?highlight=head+gasket
  10. https://www.steelsoldiers.com/showthread.php?24022-white-smoke-noise.html?highlight=head+gasket
  11. https://www.steelsoldiers.com/showt...o-needs-headgasket.html?highlight=head+gasket
  12. https://www.steelsoldiers.com/showthread.php?35604-bad-head-gasket.html?highlight=head+gasket
  13. https://www.steelsoldiers.com/showthread.php?28659-headgaskets.html?highlight=head+gasket
  14. https://www.steelsoldiers.com/showt...e-lash-info-needed.html?highlight=head+gasket
  15. https://www.steelsoldiers.com/showt...sket-leaking-again.html?highlight=head+gasket
  16. https://www.steelsoldiers.com/showt...gasket-replacement.html?highlight=head+gasket
  17. https://www.steelsoldiers.com/showt...g-m35a2-headgasket.html?highlight=head+gasket
  18. https://www.steelsoldiers.com/showthread.php?11295-all-freeze-plug.html All this for a freeze plug!
  19. https://www.steelsoldiers.com/showthread.php?15298-gasket-time.html?highlight=head+gasket
  20. https://www.steelsoldiers.com/showt...d-gasket-retorques.html?highlight=head+gasket
  21. https://www.steelsoldiers.com/showthread.php?10460-head-gaskets.html?highlight=head+gasket
  22. https://www.steelsoldiers.com/showt...roblem-perhaps-not.html?highlight=head+gasket
  23. https://www.steelsoldiers.com/showthread.php?8698-multifuel-head-gaskets.html?highlight=head+gasket
  24. https://www.steelsoldiers.com/showthread.php?5909-head-gasket-questions.html?highlight=head+gasket
  25. https://www.steelsoldiers.com/showthread.php?5757-blown-head-gasket-help.html?highlight=head+gasket
  26. https://www.steelsoldiers.com/showthread.php?4783-head-gasket.html?highlight=head+gasket
  27. https://www.steelsoldiers.com/showthread.php?2480-head-gasket-repair.html?highlight=head+gasket
  28. https://www.steelsoldiers.com/showthread.php?1384-head-gasket-questions.html?highlight=head+gasket
  29. https://www.steelsoldiers.com/showt...-158-lbs-ldt-465-a.html?highlight=head+gasket
  30. https://www.steelsoldiers.com/showthread.php?49298-head-gaskets-freeze-plugs-begins.html
  31. https://www.steelsoldiers.com/showthread.php?52752-yet-another-blown-head-gasket.html
  32. https://www.steelsoldiers.com/showthread.php?26842-lds-465-1a-inframe-headgasket-job-pictures.html
  33. https://www.steelsoldiers.com/showthread.php?52752-yet-another-blown-head-gasket.html
  34. https://www.steelsoldiers.com/showthread.php?65455-i-start-changing-out-head-gaskets-today.html
  35. https://www.steelsoldiers.com/showt...head-gaskets-dual-egt-gauge-test-program.html
  36. https://www.steelsoldiers.com/showthread.php?102749-Head-gasket-replacement-tips-and-tricks
  37. https://www.steelsoldiers.com/showthread.php?148514-Head-Gasket-Repair
  38. https://www.steelsoldiers.com/showthread.php?157931-LDT-Head-Gasket-swap-How-many-shop-hours
  1. https://www.steelsoldiers.com/showthread.php?29647-cylinder-head-wrench.html
  2. https://www.steelsoldiers.com/showt...-tool-worth-having.html?highlight=head+gasket
  3. https://www.steelsoldiers.com/showthread.php?46818-check-out-my-new-tool.html
  4. https://www.steelsoldiers.com/showthread.php?46390-photos-my-truck-2.html
  5. http://www.bunkerofdoom.com/travel/steelsoldiers1/20061027/index.html
  6. https://www.steelsoldiers.com/showthread.php?25766-engine-stand-drawings-deuce.html
USMCGunny
Quantico, Virginia
What I am interested in - and probably other newbies that have not done a head gasket job on a multi - are tips for what to do and what not to do and how to do it, from people that have done this job.
I would like this to turn into a walk-through for the head gasket job. Seeing that you clicked on this thread, it is likely that you either need this info or that you can contribute.
The TM for multi engine repair speaks to the teardown and re-assembly process. As I know from many other jobs, there are different ways for getting the work done right. If you work in an armed forces garage overhauling an engine, with access to whatever tools you need and ample time on your hands, it may be worthwhile to disassemble everything, as per TM. Experienced mechanics here on SS may be able to tell first timers, how to do a good job without getting themselves into a mess.
Some things I throw out there:
- removing valve train, yes or no? Can I leave the guts of the head intact?
- someone removed heads with manifolds, turbo etc. left attached. Advisable?
- details on block surface prepping; scotchbrite pads a no-no?
- when using m35-tom's new style head gaskets, is there any additional coating (Permatex; if so, which one?) advisable? All around or just certain areas?
- head bolt wrench; I saw many home-made ingenious solutions and a suggestion to use a 7/8 sensor socket.
I collected threads that contain some information, many are really useful, but none is "THE" authoritative thread on doing this job. My theory is that if there are so many threads on one subject, none of them has all the needed info!
http://www.steelsoldiers.com/deuce/1989-head-gasket-leak.html?highlight=head+gasket+leak
http://www.steelsoldiers.com/deuce/46425-head-gasket-what-else-check.html?highlight=head+gasket
http://www.steelsoldiers.com/deuce/46285-better-long-life-head-gaskets.html?highlight=head+gasket
http://www.steelsoldiers.com/deuce/40794-radiator-head-gasket-problem.html?highlight=head+gasket
http://www.steelsoldiers.com/deuce/...-oil-leak-question.html?highlight=head+gasket
http://www.steelsoldiers.com/deuce/44735-multifuel-head-gaskets.html?highlight=head+gasket
http://www.steelsoldiers.com/deuce/43935-bad-head-gasket.html?highlight=head+gasket
http://www.steelsoldiers.com/deuce/42476-white-smoke-need-assistance.html?highlight=head+gasket
http://www.steelsoldiers.com/deuce/40801-blown-head-gasket.html?highlight=head+gasket
http://www.steelsoldiers.com/deuce/24022-white-smoke-noise.html?highlight=head+gasket
http://www.steelsoldiers.com/deuce/38174-guess-who-needs-headgasket.html?highlight=head+gasket
http://www.steelsoldiers.com/deuce/35604-bad-head-gasket.html?highlight=head+gasket
http://www.steelsoldiers.com/deuce/28659-headgaskets.html?highlight=head+gasket
http://www.steelsoldiers.com/deuce/...e-lash-info-needed.html?highlight=head+gasket
http://www.steelsoldiers.com/deuce/23225-valve-cover-gasket-leaking-again.html?highlight=head+gasket
http://www.steelsoldiers.com/deuce/21255-head-gasket-replacement.html?highlight=head+gasket
http://www.steelsoldiers.com/deuce/16709-redoing-m35a2-headgasket.html?highlight=head+gasket
http://www.steelsoldiers.com/deuce/11295-all-freeze-plug.html
http://www.steelsoldiers.com/deuce/15298-gasket-time.html?highlight=head+gasket
http://www.steelsoldiers.com/deuce/11342-465-head-gasket-retorques.html?highlight=head+gasket
http://www.steelsoldiers.com/deuce/10460-head-gaskets.html?highlight=head+gasket
http://www.steelsoldiers.com/deuce/3182-head-gasket-problem-perhaps-not.html?highlight=head+gasket
http://www.steelsoldiers.com/deuce/8698-multifuel-head-gaskets.html?highlight=head+gasket
http://www.steelsoldiers.com/deuce/5909-head-gasket-questions.html?highlight=head+gasket
http://www.steelsoldiers.com/deuce/5757-blown-head-gasket-help.html?highlight=head+gasket
http://www.steelsoldiers.com/deuce/4783-head-gasket.html?highlight=head+gasket
http://www.steelsoldiers.com/deuce/2480-head-gasket-repair.html?highlight=head+gasket
http://www.steelsoldiers.com/deuce/1384-head-gasket-questions.html?highlight=head+gasket
http://www.steelsoldiers.com/deuce/...-158-lbs-ldt-465-a.html?highlight=head+gasket
http://www.steelsoldiers.com/deuce/49298-head-gaskets-freeze-plugs-begins.html (Garandfan changes his head gasket)
http://www.steelsoldiers.com/deuce/52752-yet-another-blown-head-gasket.html
http://www.steelsoldiers.com/5-ton-up/26842-lds-465-1a-inframe-headgasket-job-pictures.html (gimpyrobb does the job on a 5-ton LDS Multifuel; same thing at that level)
http://www.steelsoldiers.com/deuce/65455-i-start-changing-out-head-gaskets-today.html (dabtl's head gasket job and home-made tool)
http://www.steelsoldiers.com/deuce/69213-changing-head-gaskets-dual-egt-gauge-test-program.html (fire ring embedded in head; advice on installing pre and post pyrometer while heads are off)
http://www.steelsoldiers.com/deuce/29647-cylinder-head-wrench.html
http://www.steelsoldiers.com/deuce/93-head-bolt-tool-worth-having.html?highlight=head+gasket
http://www.steelsoldiers.com/deuce/46818-check-out-my-new-tool.html (how to make a head bolt tool, how to calculate torque for offset tools)
http://www.steelsoldiers.com/deuce/46390-photos-my-truck-2.html
http://www.bunkerofdoom.com/travel/steelsoldiers1/20061027/index.html (old and new style gasket side by side)
http://www.steelsoldiers.com/attachments/deuce/124833d1243124843-bad-head-gasket-deuce-052.avi (blown head gasket video with sound)
Looks like many of the links are no longer available
WillWagner
3,149
Monrovia, Ca.
I would go to SECO and get their set with the new style head gaskets. It is a complete engine gasket set, but it is worth it to have everything you need. I think they are around $280 ish. MAake sure you get the new style, modern style, 1 piece gaskets. No need to re torque, permaseal around coolant and oil passages.
WillWagner
3,149
Monrovia, Ca.
helm1008
Maine
WillWagner
That is the kit i have now. I just dont know what gaskets go to what model number on the picture i posted.
1,156
WillWagner
The vast, vast majority of that kit is not going to be used for the head gasket job.
You'll only use:
Head gaskets (x2)
Road draft tube to valve cover gasket (x1)
Valve cover gaskets (x2)
Water manifold gaskets (x6)
Intake and exhaust manifold gasket (x1 I think)
Turbo to exhaust manifold gasket (x1)
You should also do all your freeze plugs in the heads.
Menaces Nemesis
"Little Black Truck" Conservator
262
Denver, Colorado
If you're trying to make sure that the kit has all the gaskets needed for the job, none are missing, and you want to set them aside and have them ready before you start the job, just take a printout of the respective pages from the TM for head gasket replacement, along with the gasket kit, out to the truck with you. You can walk through the install pages, pulling and matching gaskets/shapes/sizes from the kit as you go. Like Clinto said, there's a whole bunch of gaskets in the kit you won't use for the job, and standing there looking at the engine it should be very obvious which gaskets are used for the heads, manifolds, and periphery. If the little crush washers that seal the injectors to the heads arent too badly battered, they can be re-used by annealing them... just heat them up to a medium cherry red with a torch, and let them air-cool, no need to quench them.
