HASSON1911
- 24
- 18
- roseau/mn
Hey thank you man you saved me there. I don't know why my TM doesn't have this in it i literally looked through every page in that book
Do you have the special wrench for the head bolts?does any one have the info, since the TM doesn't but the torquing sequence for the heads and valve covers on this truck im planing on doing mine this weekend
You should be able to find everything you need to know in the TMs.Yes we do have a socket that we found that will work. Does anybody have any the information on replacing these heads. Like valve clearance on the intake/exhaust. and any short cuts and tips or stuff we should watch out for, that would help us out when putting these heads back on. Or you know if any of you guys know a place where i could pick up a shop manual or a book about overhauling these engines. thanks
The fastest way to deal with the socket problem, is to make your own. See the pic below. Not my design, I copied it from someone else here. Just remember it changes the length of of your torque wrench, so you have to calculate the change, or keep the wrench at a 90 degree angle with the home made tool.Well, turns out the socket that my dad said would work doesn't.lol. does anyone know of a place where i can get this tool. Memphis Eqt. Also, we didn't completly tear it apart due to reason stated above, but has anyone ever had oil leaking from the heads without having a gasket blown. we're starting to think it may just be a couple loose head nuts due to the oil leaking out in very very small amounts.
