Headlight grounding?
Sand
25
Tampa, FL
Im having an issue with some 24 v LED headlights. the drivers side works fine on HIs and LOs but the other one wont turn on at all. I also swapped out the marker lights that had the ground on them. These just have a little metal ring on one of the screw holes and I'm not sure how that would be a good ground. Would a bad ground keep that headlight from working? Also, I should mention that neither side marker or blinker works either, Completely dead. Any input would be greatly appreciated.
TOBASH
3,972
Brooklyn, NY
The frames on these cars frequently do not ground.
what I did for my LEDs is I wired them into my highbeam both power and ground. I can’t envision a time when I would use the LED without the highbeam off-road. I have a switch that will keep the LEDs from coming on during routine driving on the road.
Mogman
10,596
Papalote, TX
Every light has a ground wire, none are grounded through the body or frame
