Headlight low beams keep blowing
OktobrVega
Houston, Tx
Keep blowing low beams, I have the wires connected correctly but after driving for about 5-10 minutes headlight low beams blow. Still have highbeams. What can I check?
114
NH
It sounds like a ground issue to me as well. This was the first issue that I tackled in my '84 M1009 upon purchase. Same condition... 5-10 minutes in they went pop. Cleaned up all of the ground points as none looked too great and replaced the negative battery terminal cable. No issue since. Good luck.
