headlight upgrades
jag7720
Kansas City, MO
I'd like to upgrade my headlights to a more modern and brighter bulb/system
Has anyone made any headlight upgrades?
Are there any "kits" ?
jimm1009
71
Louisville, KY
I use the Hella H4 headlight with a 60/55 watt bulb.
The light is brighter but much more focused.
It is a E-code light so it is not exactly legal for road use but as long as you keep them aimed properly you should not have a problem using them.
Do your research and you will see there are few to choose from.
jimm1009
Cucvnut
61
Carver, Oregon
i had the Hellas on my suburban with the 4 light system and they were great !
and for the ones i posted above
200mm (6 in. x7 in.) rectangular clear. Hi/low beam. 60/55 watt. Conforms to SAE/DOT standards for street and highway use. H6054 replacement unit, with HB2 replaceable bulb.
Sgt Hulka
San Francisco CA
I have the Cibie equivalent of the Hellas. Run 60/55 watters in them. I love 'em. I'd like to upgrade to the 100/80s but I'd have to put a relay and extra wiring in and probably won't go to the trouble.
jimm1009
71
Louisville, KY
Remember that the HB2 bulb is slightly different (in order to be DOT compliant) so I don't not know if the H4 bulb will plug into the same housing.
NOTE: 80 watts is beyond DOT approval and could get you a ticket if
the LEO was really sharp and inspected your lights.
Just my 1.7 cents worth but if you wish to stay legal the 60/55 will help.
On the flip side, I know guys (and gals) that have H4 lights that switch the bulbs out for offroading events that do use the 100 / 80 version and they say they are great. I beleive that there is on higher wattage bulbs than that but don't know the number.
Remember that a more precise beam can still be too bright for oncoming traffic and I don't like the idea of blinding the guy driving straight at me with a 18 to 24 inch margine for error.
This is only my opiniion and is not meant to infringe on anyone's free choice
for modifying their beloved toy. 8)
jimm1009
