fpchief
- 229
- 63
- South Alabama
I bought this truck as a parts truck and it has ended up being something I will not be parting out. It had a corroded wire #10, from magnetic relay that I had to repair to get it started. Figured I would eventually have more wiring issues. It sat down near the beach for a long time.
Replaced each connector on starboard headlight, replaced the high beam switch (used from another member, replaced because the first time I hit it for high beams it made all the lights go out)
Now, turn lights on and nothing. Hit high beam switch and only port side light works. I am getting no voltage (nothing above 2.5vdc) ar no connector. I am pulling plug off back of bucket and touching positive inside plug and got fluke ground going to chassis.
Is there a common place in the harness that may corrode and be hidden?
