I was having sever headlight problems. A fix recommended on here was to replace the fuse with a circuit breaker. I did that. The breaker would get real hot after an hour of low beam use. Much more, and the breaker would trip and I would loose lights. Which is not fun when it happens on the free way. I did more poking around on here and decided to buy the headlight booster harness from LMC Truck as suggested in the CUCV headlight circuit sticky by Warthog. I also bought a set of headlight assemblys from Amazon to replace the sealed beams. I received the harness and was disappointed to find the packaging covered in Chinese hieroglyphics. The only English on the whole thing was a set of installation instructions on the back of the package.
The harness itself was a piece of cake to put in. Every end of the harness was labeled (in English). The hardest part was finding a ground point. And there is one above each headlight. Everything went fine until I went to plug in the driver side headlight (the harness takes power from the passenger side). The harness was to short. The instructions on the package said not to lengthen the harness, but I did anyway, about a foot.
The harness is built well and the electrical contact points were all copper (as I remember). I thought it was worth the $30 but I wish it was longer. You may be able to find the same thing for less if you look somewhere other than LMC. LMC did not have their name anywhere on the package.
Also, the shape of the package showed that it originally contained two h4 bulbs ($12 apiece at NAPA) but they had been removed. I figure LMC then sells them again. Kinda dirty in my opinion. But if you intend to keep using sealed beams, then it doesn't matter.
I didn't take pictures of the install because it was soooo easy. And it was cold, and dark, and outside when I did it.
This is one of the two relays that came with the harness. one for high beams and one for low.
