HeadLights
SGT. Renshaw
Flagstaff AZ
New to the page, looking for some advice. I'm having issues with my M35A2. I have gone through several threads regarding headlights but just wanted to see if this issue has occurred for anyone else. My high beams work but no low beams. I checked volts inside the bucket at the plugs and the low beam has 16v and the high have 24. Grounds have been checked, could it be the switch or the dimmer switch? Thank you in advance for any help.
VPed
289
Clint, TX
I would check the dimmer switch. Power goes from the headlight switch to the dimmer as common to both high and low. The dimmer switch then either directs to power to the high or low circuit to the front of the truck. It could be a bad contact within the switch meaning you need a replacement. Have you tried rapidly switching the dimmer numerous times? You can do this with headlights off. Sometimes, this will clear corrosion off of contacts.
But it could also be that the switch is not properly connected. It does not matter if the high and low wires are swapped at the switch, but it won’t work if the common wire is not connected to the common terminal on the switch. That condition will result in only one of the two beams working.
