Heater Blower To Toggle Switch
Hummer Guy
703
United States Louisiana
I decided to try and get my heater working because it sucks not having defrosters in the morning. I've changed the blower motor box and it's still not working. I'm thinking about wiring the blower motor directly to a toggle switch and relay. Would there be any negative effect in going this route?
Mogman
8,287
Papalote, TX
You can wire directly to a switch if it is heavy enough, but why not actually troubleshoot and fix the problem?
Have you pulled the inst. panel and checked the switch and resistor for voltage?
TOBASH
3,010
Brooklyn, NY
Years ago, maybe 2019, a member replaced the heater box with aftermarket parts that were placed just behind the doghouse. Big heat exchanger and huge fans. Looked robust and warm as Heck.
EDIT- I found the link… You should start from the OP first post.
Retiredwarhorses
3,883
Brentwood, Calif
the heater is the simplest of designs you will find, you either have power at the blower end or you don’t when the truck is running and the fan switch is on high, if not? You need to start behind the instrument cluster, there is a single power wire to the center of the blower switch…
Hummer Guy
703
I seen that but didn't want to go that much into building a heating system since it doesn't get that cold here, I mainly just need defrosters
Hummer Guy
703
That's my problem most likely, I try to turn it on with the switch only in run, not when the truck was running, I'll get my radiator back connected and try that
