Heater core leaking
jvrotter
yucca valley, ca
OK, got home a little while ago and a big puddle under the front of my '86 Blazer. Checked inside and the heater core is leaking. So how much of a hassle is it to change one of these? Only experience with heater cores was installing one in a M151A2. What a PITA. Any good sources for one? New or used?
ssdvc
639
CT
I recently did mine. It leaked the day I brought it home and I waited to replace it (for a number of reasons). Anyway, I went to Autozone and picked up the Spector (sp) Premium Heater Core. It fit well and I made sure it was sealed all the way around so air flow went through the core, not around it. Worked good this past winter.
It is not a hard job and I made sure to put on new hose clamps at the same time (I actually did all the hoses too). There is a good write up on here and it was very helpful.
jvrotter
yucca valley, ca
Looked around can only find alum ones. Anybody know of copper/brass ones being available? Have seen a few online but not positive they will fit as I have heard of guys getting the wrong model.
Brett09
San Bernardino, CA
Why not aluminum? It has a great heat exchange and as long as you're keeping up on your service it will give you decades of use. I always like to learn something new so I ask alot of questions, sorry.
Keith_J
1,314
Schertz TX
The aluminum ones are slightly different in dimension and require special sealing to force all the air through the core. Ignore this and most air will bypass the core, leading one to think the core doesn't work. But sealed correctly, the aluminum ones work fine.
Remember, there is a pressure drop over the air side of the core so ANY leak will bypass effectively.
ssdvc
639
CT
The Spector Premium core is aluminum and it worked fine for in CT this past winter. It also has side "wings" that extend coverage better than most replacement cores. Some minor sealing with foam tape was required, but not very much at all.
