Heater for deuce
carguy455
Eddington, ME
24 to 12
Uhm...dropping resistors, easy to use, easy to find { RADIO SHACK } .....24V becomes 12V , on an electric motor like that not a huge draw, amps shouldnt be a factor really either whereas there is no heating element or anything like that.
I found a stock one too for free, also found one in a duece under the dash manufactured by Brockway, small, space saving , liked it better than the stock kit that takes up a lot of space under the hood, keeping it for the next deuce !
1,806
There also exists an M151 heater kit which is quite inexpensive. I've seen just the heater unit itself sel for $30 to $50. It's small and could be mounted in lots of different areas. Plumb in water and 28V for the blower and your making heat.
MVtrucker
Bridgeton, NJ
Whoa! $55.00 for a mounting plate? No wonder I sold out @ $15.00 ea.!
Still have heaters, but you need to come here to put a complete unit together. $200.00
JasonS
131
Eastern SD
I bought a 24 volt heater very similar to the Mojave. $35 on ebay. Made by Red Dot. Just enough BTUs to run the defroster. Very noisy.
eddiec
Southeast mo
forklift, if you can hold off for a few weeks, i can get you a heater, probably the complete kit. it'll be used, but i don't think the inside of your truck will care. heat is heat. let me know.
forklift
hello eddiec,
Definitely. any Idea how much?Just let me know when you have it. Thank you very much, jake
themunitionscache
Fairbanks, AK
I bought a circulating water heater for my deuce. When I bought it, it came with the fuel fired one under the hood and one for the back for passengers. I took those out, so if anyone wants to buy them I will sell both of them. I would like to get $300 for each. I paid almost $400 for the water one that i installed in the cab! Call me at 907-388-9907 or email me at themunitionscache@gmail.com if interested.
