coolant heater hose location too
Thanks to all. I thought it looked kinda...well...homedepot like. John, will hit up NAPA. I have you and everyone else have a VERY MERRY CHRISTMAS also!!
see post 5, 7, +9 in
Thread: Coolant heater hose location
Here is the original valve
I procured an original type off of ePay a while back with the NSN number as a search and it got me to an Eaton valve drain cock
but maybe just search for a Eaton drain cock
specifications
3/8 MALE PIPE THREAD 5/8 HEATER/ COOLANT/ HOSE DRAIN COCK 211280A VALVE
Military surplus drain cock NSN 4820-00-465-1589
New in original packaging.
Please see pictures
Drain Cock, steel, mnpt X Hose, 3/8 In. More details: Drain Cock, Seat Position Internal, Body Material Steel, Connection Type Mnpt X Hose, Pipe Size 3/8 In., Hose Inside Dia. 5/8 In., Overall Height 2-7/8 In., Max. Pressure 150 Psi, Temp. Range -65 Degrees To 250 Degrees F, Handle Material Steel, Handle Type Wing, Hex Size 11/16 In.
Multifuel top valve outlet hose size is different from the bottom valve size so I changed the bottom one to make them both 5/8" hose outlet size.
This is as it was
![CCW to waterpump original valve.jpg CCW to waterpump original valve.jpg](https://www.steelsoldiers.com/data/attachments/352/352770-1b009b36dcce8406e556a05ade877dd0.jpg)
and now with a new valve,
what a turkey to get the old one out without taking the truck apart.
![CCW waterpump inlet to same size.jpg CCW waterpump inlet to same size.jpg](https://www.steelsoldiers.com/data/attachments/352/352771-ad66ff5eff48091d53eddaeb7a9a9da2.jpg)
so now I am looking at my very own pictures wondering if I ever put back the lower water pump hose clamp!
