heater valves
digger
:confused: does anyone know where i can get a set of petcocks, or valves if you may, that are screwed into the engine block that the 2 heater hoses are attached to? My deuce has them, but the handle portions are both broke off rendering the heater useless until repaired. No luck with saturn surplus.
cranetruck
75
Meadows of Dan, Virginia
Digger, call Clark Truck Parts in Poca, WV (304 755-8811). They have many take-off parts and shipping to VA is usually next day via UPS ground.
SixBuy
Dallas/Texas
Have you checked with your local NAPA store? They have a Heavy Duty Truck Parts catalog with pictures you can compare to what you have. A lot of that stuff is standard parts. ( Did you know that a 1950 Ford tie rod end is identical to the Ford 8N tractor tie rod end? That was during the Korean War and there was a lot of that). Just a thought.
