Heater--what could be done with it?
CARNAC
The Envelope Please.
725
College Station, TX
Found a heater at a surplus store today. First thought to come to mind was "That looks neat." Then what the heck is it. Turns out my 18 years out of heavy units has made me forget what a personnel heater for an M113 looks like.
So any ideas what could be done with a 113 heater other than a conversation piece?
cranetruck
94
Meadows of Dan, Virginia
I would think that with the proper accessories, heat any vehicle. I have a similar, if not the same (30,000 BTU) unit, in my 8x8 and love it.
What's the part number?
LanceRobson
220
Pinnacle, Stokes County, NC
If the control box is with it it might be worth picking up. Remember that this critter is designed to keep an M113 reasonably warm in arctic conditions with the hatches open. It puts out way too much heat for a truck cab. It also will melt rucksacks, melt intrenching tool covers into shrinkwrap and cook off .50 Cal. ammo thats still in the can if it's in front of the heater vent. (don't ask why I know these things) It might make a bed heater for a Deuce but they are pretty power hungry and they'll run you batteries down right quick. I seem to remember that it needs to be mounted vertically. Follow the starting directions carefully or you'll have a puddle of diesel fuel in it and have a fire.
cranetruck
94
Re: RE: Heater--what could be done with it?
LanceRobson said:
....... I seem to remember that it needs to be mounted vertically. Follow the starting directions carefully or you'll have a puddle of diesel fuel in it and have a fire.
Hmmm..the 8x8 has two heaters, one is installed vertically and one horizontally. I have seen something about an "equalizer tube" on some control valves, which may have something to do with the mounting position...something else to investigate..... :?
acetomatoco
9
RE: Re: RE: Heater--what could be done with it?
M113 had a Chrysler gasoline engine.. Later versions were Detroit Diesel.
