When you say "killed," you mean ran out or damaged in some way?You'd have to have the engine running to power an inverter - just FYI. A 300 watt inverter killed a large deep cycle of mine in about an hour.
We use cement backer around the stoves where they are close to the side of our tents. You can't use it inside the heater with coal. The coal burns out the cement backer as we found out this year when we went hunting.Well the truck sure isn't air tight. I just fired it up with a few sticks, ok twigs. After the initial burn off the smoke went away from inside the back. Then it got so hot I couldn't stand it back there anymore. There will be no problems for me to stay warm in any weather. Now my only fear is it getting too hot. Will need to invest in those boards you put around fire places or will cement backer board work just as well?
