Heavy towbar to axle strap adapter
tcody
Illinois
I have a heavy tow bar and was thinking about investing in a set of axle straps to be able to make the bar more useful until I can afford a medium bar. I was wondering what type of adapters are needed to make it work - just a couple of bushings to be able to use the smaller medium pin or is there more to it?
Thanks for the help!
73m819
327
gainesville, ga.
hi, i got a set of heavy tb adaptors from semmis (i think that is the way he spells it) the adaptore have the BIG hole for the tb from he-ll and the other end has the 1" hole which fit the 1" used on the tow/lift brackets and axle clamps. hope this helps
73m819
327
gainesville, ga.
Yes,
Sermis put both adapters in one of those flat rate USPS boxes, the mail lady about had a hernia carrying the box to the house
wsucougarx
Washington State
I just picked up two complete medium towbars yesterday. They came w/1" and 3/4" bumper adapters and all pins for $450 for both sets. I could pick you up a set but shipping would be incredible
What did they cost and does he have more ? You could cut off the 1 1/2" ends and weld something with 1" holes to the end .
prob could cut and weld but i dont think i would.
the reason i got the big bar was so i could tow 2 5 tons at one time or a tractor trailer combo with out worry that the bar and ends may fail.
Its really a safety thing with me.
I know i do some things that make folks shake their heads but i do it as safe as I can.
I would think that the proper ends must be around if we were able to find them once i bet we can find you a set also.
73m819
327
gainesville, ga.
i got the tb from he-ll to tow the 819. it weighs 36000+, just about the limit of the medium, now that i have the 8x8 , in time im going to get another tb from he-ll and the same adapters as i have for the 819. maxing out the medium bothers me
timntrucks
145
Ponchatoula LA
i had a set of bronze bushings made to adapt the large tow bar ends to 1 inch. thats when i was planning on usuing that bar i sold to Tcody. i dont think ill ever need them if someone is interested just pm me Tim
73m819
327
gainesville, ga.
the 8x8 sits,
the tb from he-ll adaptors that have the big pins will NOT work with bushings on the 1"lift/tow brackets . bushings was plan A, the correct adaptors was plan B, plan A is some where in the garage
