Hello from Oklahoma
jeffhuey1n
SMSgt, USAF (Ret.)
1,653
Laramie County, Wyoming
So this is what I did with my son today on the Deuce.
1. a cigarette lighter adapter wired to the accessory switch.
2. driver side and passenger side rifle racks.
3. 24V solar trickle charger. Works amazingly well for a $30 solar panel.
Where did those rifle racks come from? I once bought a bunch of military parts back a few years and I have at least one of those upper clips. Nice to know what it’s used for.
cavtrooper78
212
Oklahoma
welcome to the addiction from way out in the Panhandle
if you need TM's on paper, just print them then put them in document protectors, got a whole shelf in the shop from TM's i needed to hold in my hand to troubleshoot something.
I thought about doing that, but with there being so many pages it's not economically feasible unfortunately. I miss being able to order pubs.
cavtrooper78
212
Oklahoma
I'm looking at replacing my 60A generator and am wondering something. I see more modern military 28V generators with like 450 amps. One of those would fry my system right?
biscuitwhistler37
1,218
Michigan
Also I came across a regulator with the following: 2920-00-116-8399 78214 LEECE NEVILLE VOLTAGE REGULATOR 28V 60A 3002AD 3002AB. Can anyone else make out what it says on my generator? I think this one will work but I want to make sure.
Yours says 60 amp, can't imagine why it wouldn't work.
Hard to read the serial number but the amperage and voltages match so I would say it's good to go
HDN
5,503
Finger Lakes Region, NY
I think you'd be fine with a 450 A generator. That's a ton of power, but the truck will only take what it needs. I think the voltage regulator is what you'd want really tested to make sure the batteries don't cook. The batteries should charge at around 28 V anyway.
For reference, I replaced the stock 120 A alternator in my 2012 Chrysler 200 with a 160 A alternator designed for the convertible version of my car. I figured the extra power couldn't hurt, especially if I wanted to install a 120 VAC inverter at some point.
cavtrooper78
212
Oklahoma
I'm thinking about having my multifuel engine rebuilt. I wish I had the shop and crane to do it myself as I've not had a big engine like that opened up in maybe 25 years or so, but I just don't. Is this something I would need to have a military specific shop do or would any diesel engine shop with a good rep be ok?
