Can anyone help me wire this? I have all the diagrams but I am no good at figuring them out.
Ground to chassis, neutral (sometimes labled white) to L0. X or black to L1 y or red to L3Can anyone help me wire this? I have all the diagrams but I am no good at figuring them out.
Thank you! What does the switches need to be set on? For this 220/110 , I am using a distribution spider box for now. When my shop is complete I'll use the 50amp rv cable to power the whole shopGround to chassis, neutral (sometimes labled white) to L0. X or black to L1 y or red to L3
Sent from my SM-G973U using Tapatalk
You should be on single phase 120/240 on the phase selector switchThank you! What does the switches need to be set on? For this 220/110 , I am using a distribution spider box for now. When my shop is complete I'll use the 50amp rv cable to power the whole shop
How about the pole switch?You should be on single phase 120/240 on the phase selector switch
Which switch are you referring to?How about the pole switch?
Can you guide me on where to hook these wires for a 50 amp plugWhich switch are you referring to?
That switch selects what the volt meter is connected to. In single phase mode you only need the 2 most clockwise positions. most clockwise is L3 to L0 and should read approx 120 the other is L1 to L3 and should read approx 240.Can you guide me on where to hook these wires for a 50 amp plug
Black to L1 red to L3 white to L0 bare to chassis (there is a lug on the front of the set below the control panel on the frame)What wire goes where? 220 plug?
